Please i need some help. When I try to enter transaction in item journal (Project >> Journals >> item), i encountered an error telling that the “Item has no parameter for inventory”.
We already check the Setup parameter for Inventory, but it didnt solve our problem.
The error message you mentioned does not look like error from standard Ax. Most likely it must be from some customisation. Try adding breakpoint for Info class → add method.
Your Excel upload did not contain all of the required system tables, review and reload. The referenced post above also gives you the tables and the answer
