I am trying to issue few quantity of an item. The item follows FIFO costing.
while trying through movement journal, we expect system to automatically pick the cost and display it on the lines. unfortunately the cost is not getting displayed over there. As we know, System won’t allow to input cost manually, becuase it is an issue type of transaction.
How do you financially cost according to the dimension group? If you look at the on hand for the same dimensions in your movement journal what is the returned cost.
You have to have a costing version - it is just that it will be empty - but check!
