We have a customised Wizard for Item code creation. What it does is
Step1 It will show the Item Group , assume user selected G1
Step 2 It will show the following customised fields (Product Group fields)
Product Group A, say user selected PGA
Product Group B, say user selected PGB
Product Group C, say user selected PGC
Also it will show the Tracking Dimension, Purchase Unit, Selling Unit and few Mandatory fields needed for creating the Item. Once all the inputs are completed, and we click on Finish, System Automatically generates the new Item code as follows
G1-PGA-PGB-PGC-0001
This is working fine.
What I need is a change in the logic of generating Item code.
The new coding structure which I need is “Item Group-0000”. Each Group will maintain the Numbering separately
e.g. if the user selected G1 , then code is G1-0001
next time if the user selected Item group as G1 , then code is G1-0002, and so on.
e.g. if the user selected G2 , then code is G2-0001
next time if the user selected Item group as G2 , then the code is G2-0002 and so on.
To cut short, whenever we create a new Item, System should check which Item Group, the user has selected and check existing items for the Last number used by the same Group and increment it by one and Generate the new code.
Hope this is clear
Regards
Thomas Philipose
