item charge
hi all i am facing a problem while doing item charge assignment.
whenever i assign a posted transfer receipt against an invoice it keeps on showing the same again and again, i need it to be removed once assigned.
All kinds of help are welcome.
There is a hotfix out there for NAV 2016, search the CU’s and you will find a fix for this issue.
my version is nav 13, is it possible in it?
