Hello, There is a boolean field- Capital Item in the Item Card. Can someone tell what is the significance of this field and how does it work?? Regards Satyajit
Hi Satya, The said field is a part of Exise. It is a part of Indian Localisation. It is used to classify an item as a Capital Item for Excies calculation as posting of deferred credit. This classification does not affect the FA Ledger. Cheers, Nitin
Hi Nitin,
We had recently implemented NAV at manufacturing industry. At the time of implementation some items were made and opening balance has been inserted on it. Now client wants that these items must be converted to capital item. now when we try to check the capital item box, it gives an error “Item ledger entry is not empty”. What can we do in this case…
Sagar
Sagar,
Did you ever find a solution to this problem? If yes, would you mind sharing it with us?
