hi,
i need the data of all item by location.
how do i get it which table to look for.
harsha
hi,
harsha
what do u mean by Data .
the form what are goen through is Matrix form.
The Base tables are Item , Item Ledger entry .
it is filtering the data from Item ledger entry by using this filters
ItemLedgerEntry.SETRANGE(“Item No.”,“No.”);
ItemLedgerEntry.SETRANGE(“Location Code”,CurrForm.ItemAvailMatrix.MatrixRec.Code);
Hi Reema,
thanks for the quick reply.
To be specific i need the items quantity by location to export it to an excel for some analysis.
so i was wondering how do i go ahead with this.
harsha
you have to do customization do get what you need .
Go on to Item By Location form: 1 Ctrl A then 2 Ctrl C and open Excel and press 3 Ctrl V.
Or if u want all entries not just available
Do the same but activity but this time click on Item Card’s Quantity on hand. Press Shift Ctrl F7 then repeat from 1. Rest u can do on excel.
And even if these does not solve the purpose u can export the entries using Sales Analysis and for every location just create a new Sales Analysis, as unfortunately the outcome cannot be filtered using location but on analysis card itself u can mention this filter. Export all of them one by one and then can merge them easily. It will be easy copy paste.
