Item AVG cost price.
How can i get the items avg cost price.
I want to get the COST PRICE it is showing in OH HAND screen for an item.
That is AVG cost price. I want to get the same on my form.
Can any one guide me how can i do this.
Thanks in advance.
Hai Kami,
In Inventory Mgmt-perioic-tranfer orders-
if you make stock transfer
in the lines – based on the item selection-- cost price is populated which is as per WT_AvG
You can replicate the same-- i think if you go thru it…will gv some idea!!
Hi Kami,
You can use avg function in select query.
static void Job40(Args _args)
InventTableModule InventTableModule;
select avg(Price) from InventTableModule;
print InventTableModule.Price;
pause;
Have you looked at the ‘averagecostPriceUnit’ method under InventOnhandItem form > DS > InventSum? That should do the trick.
Also you may want to look at ‘financialIssueCostValue’ method in ‘InventMovement’ class for different scenarios for fetching cost prices.
