Item Availability Projection Report
We find that the Availability Projection Report ignores shipped but uninvoiced items. In other words, it will show that you still have demand for the items already shipped. We are working with 3.01B. Is this the way it should work? Are there work-arounds short of a code modification for this?
Hi Hub If you are referring to the inventory availability report or the inventory availability plan I can tell you in 3.60 the shipped not invoiced items are removed from the projected available figures. I had a look on Navision’s support site and no reference is made to issues regarding this report in your version, but this does not mean it was not an issue. To correct it you would need to either modify the report, the easy option, or upgrade.[:D]
