Hi all, the item availability by period calculation does not take into account the purchase return orders of the item. So if for example you have 100 pcs in inventory and you insert a purchase return order of 2 pcs, when you go to see the item availability you see that for NAV you will have always 100 pcs and not 98 starting from a date.
I think that this error affects also the MRP calculation.
Marco
