Issues when generating PDF file from client
I am having a major issue with generating ax reports using PDF file format. If i connect using our terminal server and kick off a connection from there then everything works fine. If I connect using a client i am getting an infolog message saying the the PDFViewer class crashes in the writeBitmap method - line 64. The same happens if i select save to file or email and set file format to PDF.
I am running AX 2009 RU-5
Any ideas as I have run clean out of them.
Can’t see your code… but maybe this article can help… I’m also building PDFs and recently read through this below.
http://www.artofcreation.be/2009/04/08/winapi-rpc-1702-and-findfirstfilew/
Thanks for the link, although I found the issue, my fault as i hadnt put the correct network path in for one of the kitemark bitmaps, so worked on terminal server as thats where thay are but not on a client [:$] but this lesson will make sure i dont do it again … I hope :wink:
