Issue with RTC Menusuit?
HI experts,
I have added a page and report in RTC menusuit. It dosen’t getting reflecting in the RTC department Page.
I tired to complie the report, the page and all the menusuits but it dosent work out.
Is there any solution for the same.
Thanks in advance.
I hope you are modifying in the 10xx series only and the last menusite only…
try by restarting the service also
yes i am modifying the 10xx series only.
Not the last menusit as we have created a new menusuit in classic with id 58, i transformed to to 1058.
It was working fine and today as per requirment i added a page and a report to the menusuit.
The old menusuit is working fine but the new changes are not being reflected.
I tried by restarting the service also, but no change.
you need to add it in the last 10xx menusite…If you ahve any menusuite >1058
Hi Saurav,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
