how do i issue a SQL command query from a navision application? this is requried so that i can read or probably insert data into another table for some integration between 2 different databases.
There was a discussion about this just a few days ago. The conclusion there was to install Enterprise manager. Then You get an automation object You can use. It should be possible to use ADO also. I think I would prefer that. //Lars
i have done some search on this and i can’t seem to determine where a similar discussion as this took place. mind helping me here…
Try searching on ADO. I know I’ve posted a couple here. Bill
