Dear All,
Plz find the Issue
PO number generated (in this case 053344) with qty in it (54).
Start à RF Gun Scans the PO number ( which automatically updates the qty to be scanned and put away) à Serial numbers (bar codes) are scanned from a set of core fascia’s which have been received à As soon as the quantity=54 the handheld device uploads the data to AX (this process takes a lot of time) à A work id (# 373421) is generated for which label is printed and scanned with the same handheldà This work id is associated with the PO and the qty scanned in à Then the entire work id is uploaded to a put away location which is a bin
Plz suggest me where is the problem and suggest me wat are the best way’s to solve the issue
