Issue regarding the Batch number for sales return order
HI All
When i try to do salse return order system is throwing below error kindly advise
I do not believe that is standard processing, so either a customization or localization. It is saying you cannot return the same batch number as shipped. Either way it is telling you to go into the registration and register the stock in.
Hi Adam Roue
Its a customized one and this error accrues while registration
Its no doubt a customized one and what I see from the error is that it is trying to specify that the order is for returned item and it needs new batch number to be registered against. Use the new batch number dimension for this and then try.
Really difficult to help on customizaed code without knowing the customization.
Agree Steven :slight_smile:
