Issue on running sales tax transaction SSRS report in AX 2012
I am getting an issue while running standard sales tax transaction report. There are no customization at all.
Issue is something like this:
An error has occurred during report processing. (rsProcessingAborted) Query execution failed for dataset ‘TaxTransDS’. (rsErrorExecutingCommand) An exception occurred in the query metadata execution. The exception is No data to create a bookmark. Parameter name: queryRun. No data to create a bookmark. Parameter name: queryRun No data to create a bookmark. Parameter name: queryRun
There are actually few different cases:
  1. If I select no parameters, then it throws error.
  2. If I select particular voucher or some range(up to 2000), it runs perfectly.
  3. If I select date only, and there are less than 2000 transactions for that date, then it runs fine else throws an error.
1 thing that I found is , maximum pages which are displayed when/for no. of records report runs are 46. I have tried with different no. of records, everytime max page is 46. It is clear that there is some issue with quantity of data which needs to be displayed on report.
As much i have reasearched, it seems some issue with buffer size but i am not sure. Please reply if anyone have proper solution for this.
Any updates on this??
