Issue in Attaching a report, while sending E-mail
I am generating a report, and mailing it to the the vendors in AX 2009.
When i mail from the the client side (Class running on server side) - No issues.
But my requirement is send the mail from server side.
Some times i am getting the error message
"Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x80040211 () which means: ".
While attaching sometimes it is taking the backward slash in the file path , sometimes forward slash. i am not getting when i need to give forward slash and backward slash.
Here is my code, (Class Running in server side)
void sendMail(LedgerJournalTrans _journalTrans)
SysMailer mail;
InteropPermission interopPermission;
interopPermission = new InteropPermission(InteropKind::ComInterop);
interopPermission.assert();
mail = new SysMailer();
mail.SMTPRelayServer(SysEmailParameters::find(false).SMTPRelayServerName);
mail.fromAddress(Setup.SenderMailId); // Sender mail id
vendTable = VendTable::find(_journalTrans.AccountNum);
mail.tos().appendAddress(vendTable.Email);
mail.priority(#priorityValue); // 2
// Build the Message
mail.htmlBody(#mailBody + #newline);
mail.subject(#mailSubject);
mail.attachments().add(fileName);
//mail.attachments().add(strReplace(fileName,#backSlash,#forwardSlash));
mail.sendMail();
info(strfmt("@xyz1406",_journalTrans.AccountNum)); // Payment Advice Report is generated and mail is sent to the Vendor %1
These are the two lines causing the error, i couldnt get which one to use when my code is running in server side.
Thanks & Regards,
Arun B S
Hi Arun,
I too got the same error and i found that the error is related to SMTP user name and password.
I provided wrong password for my SMTP user name.I provided the correct on and it’s working fine with attachment.
Please find the below code which i used to send amil with an attachment
static void sendMail()
CustInvoiceJour custInvoiceJour;
Args args = new Args();
CustInvoiceJour custInvJour;
InvoiceId _Invoiceid;
SalesId _salesId;
Email mailid,mailid1;
PrintJobSettings printJobSettings = new PrintJobSettings();
SysINetMail m = new SysINetMail();
str fileName,filename1;
SysMailer _sendMail;
InteropPermission perm;
ReportRun report;
RecordSortedList List = new RecordSortedList(62);
Args argsInv= new Args();
Args argsPOS= new Args();
Reportrun reportInv;
Reportrun reportPOS;
try
fileName = DocuParameters::find().ArchivePath + “\test.pdf”;
perm = new InteropPermission(InteropKind::ComInterop);
perm.assert();
custInvoiceJour = CustInvoiceJour::findRecId(5637151333);
_Invoiceid = custInvoiceJour.InvoiceId;
_salesId = custInvoiceJour.SalesId;
select custInvJour where custInvJour.InvoiceId == custInvoiceJour.InvoiceId;
//for creating first pdf file for salesinvoice Report
mailid = CustTable::find(custInvoiceJour.OrderAccount).Email;
argsPOS.record(custInvJour);
argsPOS.name(reportstr(SalesInvoicePDF));
reportPOS = Classfactory.reportRunClass(argsPOS);
reportPOS.setTarget(PrintMedium::File);
reportPOS.printJobSettings().format(PrintFormat::PDF);
reportPOS.printJobSettings().fileName(fileName);
reportPOS.init();
reportPOS.run();
//for attachments and sending mail
_sendMail = new Sysmailer();
_sendMail.SMTPRelayServer(‘SMTP server name’,25,‘SMTPusername’,‘SMTP Password’,false);
_sendMail.fromAddress(‘SMTPusername’);
_sendMail.tos().appendAddress(‘tomailid’);
_sendMail.attachments().add(fileName);
_sendMail.subject(‘Subject — Test mail’);
_sendMail.htmlBody(‘Please Find the Attached Sales Invoice’);
_sendMail.sendMail();
CodeAccessPermission::revertAssert();
catch(Exception::Internal)
throw Exception::Internal;
you better ask your admin for the credentials.
Thanks & Regards,
Britto John Baskar.A
