Thats fine… But I want to customize the form depending upon the Navigation Path, ie.,from which section the Accounts form is opened,(from Sales or Service Navigation Menu) . How can I get the Navigation Path at runtime?
I’ve never seen that, on the other hand if you want to customize the fields for the user permissions… why don’t you just use the user role to set the visible or editable properties?. Doing it this way you will not customize the form when it’s called from Sales (for example), but you can customize it for the users that has the “Sales-role”… did I explain?
