A form was created using ListPage template. The datasource of this form is a query. I need to create a display method which will show data originated from the table SecuritySubRole, which is a table from AOT\System Documentation\tables. So creating a display method in this table is not an option. Maybe a method from the query or the Interaction class can be used?
Why do you want to place the display method on the table containing the data? What’s the method going to do?
I need a field Sub-Role shown on the form. This must be NoYes Enum. Just to show whether a sub-role exists or not for a particular role. There is no such field in SecuritySubRole.
I’ll create a view based on the above-mentioned query and I’ll create a computed column. It should work.
