Is there any way from an external source - sort of like a URI/URL type link - to jump directly to a sales order (for example).
Using NAV 3.70
Rob
Using NAV 3.70
Rob
Hi Rob
Yes, you can create a link to a form in Navision. Open the form and find the record you want to create a shortcut to. Go to File - > Send - > Shortcut to Desktop or Link by E-mail.
Regards
Claus
If you search through the posts I posted a response a while back on how to Dynamically create the links in Navision so you don’t have to click the file etc… you could just click a button and it would build the link for you, then you could add it to an email and send it.
I know, pure laziness, but good none the less.
Thanks Tony - did a search, but nothing seemed to pop out. Any help locating the message would be great.
Easiest way is to click the # of posts above the points on the left.
That will show you all his posts - then you can type the word “link” and filter his posts.
You’ll find → http://dynamicsusers.org/forums/thread/2393.aspx
