I have to add field as array in table. I am using NAV 2016.
cant have an field as an array in the table
Not quite sure what you example want to do. But you can create a variable for example CustomerList type = Code (In View Globals,) If you then do Shift+F4 then in Dimension you can type 10
With that you have values as CustomerList[X] where x can be between 1 and 10.
Thanks all for the reply…
