As said in the book Microsoft Dynamics AX 2009 Programming: Getting Started it´s needed to put semicolons after declarations in x++:
The extra semicolon after the variable declaration is mandatory as long as the first line of code is not a keyword. The semicolon tells the compiler that variable declarations have come to an end. You cannot declare new variables after this semicolon.
(copied directly from the book, unchanged, if needed i´ll remove it)
However, when i remove the semicolon and run the job, there´s absolutely no error or problem:
static void Job1(Args _args)
str string1 = "STACKOVERFLOW";
print string1;
pause;
works just as
static void Job2(Args _args)
print string1;
pause;
Is it really needed ? should i get used to using it ?
Thank you
