Is it possible to show two tables column data on one column ......?
Hi ,
Is it possible to show two Tables data on one column…
Let us take example …
Form_C have field ID.
ID field have look up, getting look up from look up method on that field control ID.
In that look up method TableA is used
  • sysTableLookup.addLookupfield(fieldnum(TableA , ExtractProdId))
… Data is showing on ID field from TableA
Is it possible to show TableB data include TableA data on same column. I mean Form_C ID Field
Reply is appreciated
Dear Kumar,
It is not possible to have multi table lookup using Lookup method.
There is a way to do so, just make a query, by query make a view and just use this view as datasource in a form and make this form your Lookup form.
For Example
Query : JMSLookupQuery
View : JMSLookupView
and Form which using this view as DS : WCL_JMSItemLookupForm
Code for Lookup Method is
Args args = new Args();
FormRun itemLookUp;
args.name(formstr(WCL_JMSItemLookupForm));
args.parm(Num2str(WCL_JointMeasurementLine.JMSRecID,0,0,0,0));
args.record(WCL_JointMeasurementHeader);
itemLookUp = new FormRun(args);
itemLookUp.init();
this.performFormLookup(itemLookUp);
Verify if Correct solution !!
B K
You can display fields from several tables in a single lookup if you build it with SysMultiTableLoookup class.
Martin,
Requirement is , in lookup on one column data have to show from two different Tables column…
Dear shram ,
Thanks for fast reply,
My requirement is in look up one column have to show data from two different tables…
EG: Form_C have field ID
ID column have look up . That look up is getting form look up method
My requirement is ID column have to show data form two different Tables …
I mean Form_C ID column Data have to show form TableA and TableB
I was reacting to the statement that it is not possible to have multi table lookup using Lookup method.
If you want to concatenate two fields to one, my advice is: change your requirement. You have two fields, so show two fields. Otherwise you have to use some workaround, e.g. filling calculated values to a temporary table and showing the temporary table in the lookup form. A view with a calculated column is another option (AX 2012 only).
Martin/ sharam
Thanks for your valuable time …
