We have developed a Add-On module to “Dynamics NAV 2009”. This Add-On is developed based on “Indian Version of NAV 2009”. Now we would like to implement this Add-On module to Non IN region customers like W1, NA, AU, GB, NDL, etc.
Is it possible to implement the Add-On solution of “Navision 2009 Indian version” to other region customers? If it is possible please suggest us the way.
You will need to test on each localization as objects can be different in different region e.g. we have a problem with one add-on which worked on GB.W1 but not on IT due to a different standard function call.
You will also have to consider language pack for some regions
