Is it possible to have 2 forms with same datasources in the same privilege and have different access levels?
I have a security privilege with 2 display menu item entry points. EntryPoint1 is responsible for accessing Form1 and EntryPoint2 is responsible for accessing Form2. The Permission subnode of the privilege is completely empty.
Form1 and Form2 have the same table as FormDataSource.
I set these values for AccessLevel property of the entry points:
EntryPoint1 —> Delete
EntryPoint2 —> Read
The result was that a user associated with this privilege (via role and duty), could update, create and delete records in both forms, Form1 and Form2. So system gave the user full access to both forms.
My question is this: Is it possible to have 2 forms with same datasources in the same privilege and have different access levels?
From what I’ve seen in my tests, I can say that AX chooses the highest access level in the above case.
