Is it possible to debug display methods when printing SSRS report from AX2012?
If it is then how?
The SSRS reports that I have looked so far in AX 2012 are using a classes to populate temporary table(s) which are then used by SSRS report.
Which report are you referring to?
Any report :slight_smile:
When you add data source for ssrs report you can choose fields, field groups and display methods. It is after data is populated to tmp table in RDP case.
But the question, is there any possible way to debug display methods? Have anyone tried?
