Is it possible to change PO line Dimensions once Invoiced
We have posted some Purchase Invoices without any value in the PO line Dimensions. Is there any way that we can update the Dimensions with a specific value.
Some one told me, through AX, this is impossible, but through SQL we can, but doesn’t know the consequences
Or else, what is the recommended solution?
regards
Thomas Philipose
The recommended approach is to reverse the original PO and post it again with correct dimension set. I will never recommend to update any data from backend until if that is a small fix not related to transactions.
Pranav…
