Is it allow to post the JV without updating the dimensions?
What is JV?
Journal Voucher
Ok, there is nothing called Journal Voucher in standard NAV W1. Is it the same as the “General Journal”?
Yes. An old entry posted with wrong amount without updating dimensions(approx. 2 yrs back). Now I want to reverse that entry without updating dimensions. But the system is not allowing this.
Can you be more specific about the system error?
"A dimension used in Gen. Journal Line JOURNAL VO, AUTOJV, 10000 has caused an error.
Select a Dimension Value Code for the Dimension Code PRODUCT."
PRODUCT is global dimension code 2.
I think you are missing the selection of dimension code value for PRODUCT at time of posting of process, check dim. before posting.
Actually I want to post without dimension. Please read the previous posting…
2 years back you must have not set Code mandotory option for Product Dimension on account which you are trying to post now…
I am not sure why you are reversing an entry which is posted 2 yrs back…
You can temporarily remove code mandotory check and post…
Dont forget to set code mandotory on account after posting…
