Invoiced Report
I need a code send a present invoice report
Why exactly don’t you want to use the logic intended for and doing what you want?
I’m new to AX so I have to know to that.
Then you should be exercising your coding skills and not your ability to ask questions in discussion forums, shouldn’t you?
You won’t be able to get a printed report (to PDF in your case) without printing it at some point. But maybe the task is about something else - you should ask the mentor, not us, if you’re not sure.
