Invoice Capture Solution - auto populate the freight and taxes information from the invoice
Hi ,
I would like to get some thoughts around this with the out of box invoice capture solution , if invoice contains lines with quantity, freight or taxes on the same section i mean pdf document, after capture MS solution not auto populate the freight and taxes fields, need to manual select every time.
Tried to teach the AI model by uploading 10-15 invoices but no luck. Please let us know if needs to customize the model to make it work or any best practice to achieve this would be great help .
We’ve had some success using a large language model instead of a trained model to interpret output from files. You can ask an LLM to review and summarise in (for example) a JSON format that you specify, and then parse those results. I don’t know why your trained model is stuck, but if it’s due to variability of input then an llm may work in this context. Hope this helps, happy to talk!
Hi Alex,
Thank you so much for your response. I used standard out of box solution or model to capture the invoices. Please share me the documentation if you have on using LLM model to train the invoices. Thanks
That’s a common challenge with the out-of-the-box Invoice Capture solution. The AI model often misses freight and tax fields when they appear in the same section as line items.
This can usually be improved with proper methodology, like refining training data, adjusting field mapping, or applying light customization in F&O to help the model identify those fields better.
If you’d like, we can schedule a quick free audit session to review your setup and suggest the best approach.
