I have the AX’s relation inventtrans.inventransid = purchline.inventransid
but When I apply a join I obtain multiple lines, I found that’s because there are 2 or more lines in inventrans (in some cases), with the same transrefid, itemid and inventransid.
What Does this situation represent? If would be an error, What can I do to obtain the correct line
in inventrans? What is the true line that affected the inventory?
It’s not an error. It happens when, for example, you have an order with a purchline for qty 5, and you post a packing slip for qty 2 for this order. You then will have two inventtrans records for this one purchline: one for qty 2 as received, and one for qty 3 as ordered. When you ‘mark’ the purchline (to, for example, a salesline of qty 1), you will have another split in your inventtrans records to represent this new situation (for the situation with which I experimented, the inventtrans with qty 2 was split in two inventtrans records, each with a qty of 1, and one of these new inventtranses has a value for the reference lot - refering to the salesline to which I marked the purchline). Like this, all action to a purchline has some effect on the linked inventtrans record(s).
So probably your inventtrans records have a different status, or have one or more fields that are filled in differently, showing evidence of how the purchline was handled.
