InventTrans Error
Hi everyone,
I was trying to open the Inventory reports
INVTY MNGT>REPORTS>TRANSACTION
and this error appeared.
I synchonized all the tables in AX, and no error was found.
If this error do not appear, the UNBALANCED X++ TTSBEGIN/TTSCOMMIT appear instead.
please help.
thanks
There may two reason first is you cache memory have some garbage data or in your invent trans there is records which sales order is manually deleted.
Hi Ashish,
yes, i think i deleted some SO. So would i get rid of that error? or how to prevent that from happening again (Aside from manually deleting SO) ?
thanks
I checked the SQL, and found the garbage data. How can i get rid of it?
