I run Navision’s Inventory Valuation Report for an item as of 10/31/04, and I get a value of $1,000. I run the same report for 09/30/04 and I get a value of $500. Is there a report I can run that will show the transactions that occurred in Oct. and “tie out” to the Inventory Valuation Report. I am aware of the Item Transaction Detail Report, it does not however “tie out” to the $500 worth of transactions. Does anyone know of such a report?
on the Option tab of the report, you can select to print details.
You can create a report based on item ledger entry and va;ue entry on the logic of , if value entry.posting date > item ledger .posting date then curreport.skip. Hope this works
