Inventory Valuation-WIP report
Hi There,
I don’t want to the records where cost posted toG/L is zero.I tried to filter by this field setting it<>0 0 but it didn’t help.Please help me.
Thanks in advance
Preet
The standard report runs from teh production order table and the value entry, you cannot filter on teh value entry as it is not available. A slight change to this report setting the Value entry data item ReqFilterFields to Cost Posted to G/L will see it appear as a tab for filtering and then your <>0 will work. However you will need to test this gets you what you want.
