I have a client on version 2.50 that would like to run a report that will give them the value of their inventory as of today. Problem is the Inventory Valuation Report in version 2.50 does not have an options tab with As of Date as one of the filters. How do you run the Inv. Valuation report in 2.50 and use date filters?
You can’t run the report and expect correct values for a historic date in 2.50 if You have done adjustments after the date You are interested in. This is because there’s no detailed ledger entries (value entries) like in newer versions.
