Dear Guys,
I am preparing a report on “Inward Inventory Transactions”, and I need to use a dialog named “WAREHOUSE”. But “InventTrans” table doesn’t have the field “WAREHOUSE”…Then how can we fetch the “Inward Transaction” ?
Dialog Fields : ToDate, FromDate, Warehouse
Fields In Report : ItemName, Qty, Date, ItemDimension
There will not be warehouse field in Inventtrans but combination of different dimensions do exist in inventdimid field, So just extract the inventlocationid(Warehouse) from inventdimid field in inventtrans. Ex: inventdim::find(“inventdimid”).inventlocationId // this gives you warehouse from inventdimid
Thanks for your reply sir… I wrote the following code , kindly suggest me / correct me if I am wrong:
Class Declaration :
public class ReportRun extends ObjectRun
TransDate FromDate;
TransDate ToDate;
InventLocationId Warehouse;
DialogField dlgFromDate;
DialogField dlgToDate;
DialogField dlgWarehouse;
Dialog :
public Object dialog(Object _dialog)
DialogRunbase dialog = _dialog;
dlgFromDate = dialog.addField(typeid(TransDate),‘FromDate’,’’);
dlgToDate = dialog.addField(typeid(TransDate),‘ToDate’,’’);
dlgWarehouse = dialog.addField(typeid(inventLocationId),‘Warehouse’);
return dialog;
GetFromDialog :
boolean getFromdialog()
boolean ret = true;
FromDate = dlgFromDate.value();
ToDate = dlgToDate.value();
Warehouse = dlgWarehouse.value();
return ret;
Fetch :
public boolean fetch()
InventTable inventTable;
boolean ret;
this.query().dataSourceNo(1).addRange(fieldnum(InventTrans,DatePhysical)).value(queryRange(FromDate,ToDate));
this.query().dataSourceNo(1).addRange(tablenum(InventTrans,
// ret = super();
return ret;
