Dear ALL,
I am working on a particular customization for my client, where i need to add supplementary items to every main item created in the Purch line. The client does not want to to use the Std Suppl itemCreate Classes & its functionality. Therefore I added two extra field in the Purch line ( 1. Supplementary Item, & 2. Its qty). Then on click of a button I am creating a new record in the datasource level and entering the desired values. After this all the Purchase order related functions are working properly. But the supplementary item for which I created a record through code, there is no Inventory Transaction, It is not getting enabled even for the registration process. For your Reference I giving the code what i have written at the button click method.
void clicked()
int updatereccount = 0, newreccount = 0 , containersize;
PurchLine buffer,updatebuffer, purchline3, newrecbuffer;
ItemId _itemid;
boolean ret = true;
super();
if (ret == true)
ttsBegin;
glbbuffer = conNull();
buffer = Purchline_ds.getFirst(1);
while(buffer.RecId != 0)
if((buffer.SupplementaryItemId != “”) && (buffer.SuppItemQty >= 1) && (buffer.SupplUnit != “”))
glbbuffer += buffer.SupplementaryItemId; //1
glbbuffer += buffer.SupplUnit; //2
glbbuffer += buffer.SuppItemPrice; //3
glbbuffer += buffer.SuppItemQty; //4
glbbuffer += buffer.RecId; //5
buffer = Purchline_ds.getNext();
containersize = conLen(glbbuffer);
while(containersize != 0)
_itemid = conPeek(glbbuffer,1);
select forUpdate updatebuffer where updatebuffer.PurchId == Purchline.PurchId
&& updatebuffer.ItemId == _itemid
&& updatebuffer.PurchItemType == PurchItemType::Suppitem;
if(updatebuffer.RecId)
updatebuffer.PurchQty = conPeek(glbbuffer,4);
updatebuffer.PurchPrice = conPeek(glbbuffer,3);
updatebuffer.PurchUnit = conPeek(glbbuffer,2);
updatebuffer.ParentItem =conPeek(glbbuffer,5);
updatebuffer.update();
Purchline_ds.reread();
Purchline_ds.refresh();
updatereccount++;
else
Purchline_ds.create();
PurchLine.ItemId = conPeek(glbbuffer,1);
PurchLine.PurchUnit = conPeek(glbbuffer,2);
PurchLine.purchprice = conPeek(glbbuffer,3);
PurchLine.PurchQty = conPeek(glbbuffer,4);
PurchLine.ParentItem = conPeek(glbbuffer,5);
PurchLine.PurchItemType = PurchItemType::Suppitem;
PurchLine.PurchaseType = PurchaseType::Purch;
PurchLine.PurchStatus = PurchStatus::Backorder;
PurchLine.ProcurementCategory = EcoResCategory::find(EcoResProductCategory::findByItemIdCategoryHierarchyRole(PurchLine.ItemId,EcoResCategoryNamedHierarchyRole::Procurement).Category).RecId; // bharath as on 27/06/2013*/
//element.insertInventtransOrigin();
// element.CreateInventtransPostingVoucher();
// element.insertInventtrans();
newreccount++;
glbbuffer = conDel(glbbuffer,1,5);
// buffer = Purchline_ds.getNext();
ttsCommit;
PurchLine_ds.executeQuery();
Purchline_ds.research();
Box::info(strFmt(“For %1 Purchase Order %2 Records updated & %3 Records created”,buffer.PurchId,updatereccount,newreccount),“Purchase Order”);
Please tell how to resolve this issue.
Thanks & regards
Bharat V
