Hi, When open Inventory top 10 list under design mode, stand on data item as ITEM, Press Shift F4 to view properties, look for ReqFilterFields & if I need to add a new filter, I would press F6 to look into Field List & press F6 again to add a new field & browse for fields starting with G, I can find two fields as Global Dimension 2 Code and Global Dimension 2 Filter, what is the explanation for these two fields. If you guys have any reply I would welcome it! Regards Khan\
Dimensions is a fundamental concept in Navsion, allowing you to analyse (financial) data. You can setup Dimensions on master data, allowing you for example to view sales figures per product group, area, company size, … whatever.
