Hello - I am looking for a reporting mechanism to capture all inventory revaluation journals in a date range as a tool to reconcile the Inventory Adjustments account. Please help Thanks
Hi Brian The revaluation journal will have a source code assigned in the trail codes → source code setup. If this is unique you could run the item registers report filtering on the appropriate source code.
