Inventory Recalculation
Hi AX Expert,
I have done the inventory recalculation.
But the recalculation result between inventory value report and ledger voucher transaction report are not same.
Seem like some of the balances in inventory report is not posted to ledger.
Example :
Recalculation voucher : 0000001
The amount of recalculation voucher “0000001” in inventory report : 3,000.00
The amount of recalculation voucher “0000001” in voucher transaction report : 2,800.00
Hope someone could help me for this issue…
Note :
I’m using weighted average for costing.
Jimmi
I think the better approach will be to match Inventory value report with ledger balance first, just to make sure that both the balances are matching.
Secondly, how’s the difference when you see the voucher in GL, what’s tha balance for that voucher. This way, it will be identified which report data is misleading.
What AX version are you using, inventory value report had few issues in earlier version.
Pranav…
Hi Pranav,
Thanks for your replied.
I’ve already compared the inventory value report and ledger and the balances are not matching.
I found out the differences came from recalculation voucher.The recalculation voucher balance in inventory report did not match with balance in ledger balance.
And I tried to compare the settlement details with ledger but it’s difficult because i run the recalculation with specification “Total” so the balances in ledger are lump sums.
Note:
I’m using AX 2012 CU 7.
Jimmi
