Inventory Manual
Is there a Inventory Manual? Where can I get it? I am interested in see the way data flows through the Navision.
Hi Robert, All the Navision manuals (including the Inventory one) are available on your Navision CD. They are all in the Adobe’s PDF format. As far as data flow is concerned you won’t find that in the manual. You can use a tool called Impulse Workbench which will help you to identify the relation ships between objects, fields, etc … If you have got a developer licence you can aslo run the program in debug mode so you can trace step by step what Navision is actually doing. Tarek tarek_demiati@ureach.com Edited by - Tarek Demiati on 2001 Aug 04 11:29:02
