inventory management
hi Friends
i want bag serves … i have ax 2009 and i want to see on hand quantity in " inventory management "
I want the actual Quantity in my warehouse
please tell my any report
thank you
Inventory Management > Inquiries > On hand.
It displays the list of all the on hand items present in your warehouse.
Thanks & Regards,
Parashar Banerjee
hi
for reports u can see from
inventory → reports ->on hand
for actual qunaitty
inventory-> item master → select the item → on hand
Thank you for replay
but i can’t see item master
if you choose one item to see actual qunaitty this is ok nice
but i want to see all item in my Warehouse
Thank you
Hi Mohamed,
Click on-hand inventory in the form u have just sent. Then click Select.
A on-hand inventory report box will come. select the desired item no from the drop-down criteria box. then click ok
Then the selected item no(whose on-hand report you want to generate ) will come in the on-hand inventory box automatically. Then click ok. The report will get generated with all the details,
Thanks & Regards,
Parashar Banerjee.
If u want to see all the on hand items present in your warehouse, follow this path as i said u earlier.
thank you sir
I see all item in my warehouse but I CAN’T see TOTAL qunaitty
and i see more Details
-Posted quanity
-received
-physical reserved
-available physical
-ordered reserved
i want to see only available physical
Thank you
Sir , i want As report
thank you
Is your problem solved now…???
no i see more Details … i want to see available physical and Total Item
-Posted quanity
-received
-physical reserved
-available physical
-ordered reserved
Thank you
You can see all the details like Ordered physical, Available physical, physical reserved in that form only → Inventory Management > Inquiries > On hand.
Moreover if you want to see the total items based on warehouses then in that form click Dimensions Display > Select Warehouse > Save set up > Ok.
Thanks.
