Inventory journals
Hi!
I’m just curious why posted transactions on inventory journals can be deleted?
Schneizer
The respective journal name might be having the delete lines after posting setup enabled.
Hi Kranthi,
I’ve checked the journal name setup. I can manually delete posted transactions. I’m just comparing the inventory journals and financial journals. Any idea why it behaves like this?
Schneizer
The ledger journals have more controls than the inventory journals.
But you can still delete the ledger journals through journal clean up or by enabling the delete lines after posting setup.
It does not delete the transactions, just the source journal.
A bit like deleting a sales order that is invoiced, you can but you cannot delete the supporting posted transactions.
Yes
