Inventory dimensions check on form
Hi Guys,
I am creating a form having Item, dimensions and dimension display button on it, but I have some troubles with dimension validations:
  • I have two DS on it MyTable and InventDim connected by inner join
  • write and validateWrite methods are updated so the saving of dimensions work properly
  • Item field on MyTable is named ItemId which enables relation checking
  • dimension display botton works OK
  • I have updateDesign method run from form init (using InventDimCtrl_Frm class)
Everything works fine except for validations of dimensions when they are set as mandatory - i.e. I am able to save a line without setting siteId eventhough it is mandatory parameter.
Does anybody know what I am overlooking? Where this check must be set (I thought it is part of InventDimCtrl_Frm…?). Even some guide for would be OK.
Eventually I chose simpliest solution which was to put the validations on validateWrite where I call dimension validation methods on InventDim, works good…
