Every time you get an “Internal Error” Navision displays a
Module number, that tells you a little more what the error is due to:
1 Operating System
5 Trees (keyed index trees)
9 Type
11 Attributes
15 Stack Manager
17 File
18 Large Fixed Decimal Numbers
19 Database
24 MiniTree
25 Help Lookup
27 OIO (backup and restore?)
30 Presentation Object Manager
35 OCX
36 OCX Type
40 RunTime
41 Evaluation
42 Format
45 String
46 Date
47 Text Conversion
50 Binary Coded Decimal (Decimal No.)
60 UA (The connection between the Database and Forms)
61 UA_Control (Controls use in the connection between the Database and Forms)
70 Application Object
71 Report Object
77 Dataport Object
80 Execute External Program
81 Form Object
101 AL_Run (C/AL Stack Machine Interpreter)
102 C/AL (compiler and editors)
103 Codeunits
110 Data Manager
111 Wizards
112 Printer Driver
160 License File
165 unknown (fields?)
169 Binary Object Import/Export
200 Development System
243 NetBIOS
244 TCP/IP
500 TAB
Hello. Here’s what I know about this error. Prior to version 1.2 you could get this error if you have more than 13 fields in one key. The module is the ZUP module. One possiblility, therefore, is to rename the ZUP file to something else, as it may be corrupt. The error definition is: #Err_Zup_PutDataSize (Module_Zup,Err_Fatal(2)). If the user is on pre version 1.20, you should upgrade them. Michael
