Internal Error 2 in module 7
While generation of report there is no error. I entered few transactions also; during this also there is no error. This error is faced while we exit from Navision.
system gives an error i.e. Internal Error 2 in module 7.
Hi avg
You don’t say which version of Navision that you are using.
I have seen this error before, it was due to some customisations made to Codeunit 1.
The problem was that some custom variables had been defined as global rather than local.
http://www.mibuso.com/forum/viewtopic.php?t=10473
If this is a custom program. Export the program and run it again Cronus vanilla database. And see what happens.
Try removing your ZUP file to see if it cures it.
