Can anyone recommend the best way to go about intergrating the Payroll from navision(Database) to a SQL database. I need to update the SQL db either end of the day or on update of data within payroll. This is only for employee data(Employee Table). I have basic licence and do not have the time to export from navision to a file then into SQL. If possible automatically… Thank You David H. Network and System Interface Specialist Associum Consultants Toronto, Ontario
I recommend the best way to go about intergrating the Payroll from navision(Database) to a SQL database is configure the SQL database as a back up and use this back up data of SQL database the way you want to use.
