intercepting key presses
hi there is there a way to intercept the pressing of the ENTER key? i dont mean any validateing process or the OnDeactivate trigger. i just want to execute code if the user presses the ENTER key inside a field. bytheway: is it possible to tell a TextBox inside tablebox to jump into the next line? thanks bye
i am not sure about the the keypresses, but there is an onInputChange event which is fired on the key presses. About moving to next line, u can do it by giving the id on the control in the ‘NextControl’ property of the textbox & setting the ‘AutoEnter’ property to true. But this will happen only after the maximum length of its ‘sourceExpr’ is reached.
