Integration Zetafax NF
I have a little experience with the zeta-fax . the only thing i’ve done is sending a report automaticly to a number. To do so you have to put a “%%[to:003251313630]” in front of your report and a “%%[send]” at the ending. Then send the report to the Zetaprinter and the zetafax won’t ask you a number to send to … he’ll use the number after the %%[to: But i also have a problem : in the overview of zetafax there is no name of the recipient known; i would also like to send the name (not only the number) to zetafax) Can someone help me with that ? Thanks Tom
%%[TO:Faxnumber,Contact Name,Organization] will do the trick for You. For more information. Look at http://www.zetafax.com/teknotes/ZTN1011.htm //Lars
