Integration with Fax
hi friends, There is one customer requirement , they want to send their customer statement through FAX, have any body done this sort of integration. reply me.If we run customer statement report then for those customer which have fax no. on customer card statement goes through FAx and which are not having fax no. statement report must print from local printer.
Did you try searching the forum for FAX?
Hi Nelson, why didn’t you say them that you have worked on an integration to SBS ? I KNOW : THEY SHOULD USE THE SEARCH FUNCTION !!! Sorry, I had to do this…
[:D][:D] If Deepak reads the topics related to the FAX subject, he will get a very, very good overview of possible solutions and problems.
Well… winfax works pretty good with navision… and integrating navision reports with winfax it’s really not that a hard thing. :slight_smile:
Please Close this topic. Thanx
Take a look at Zetafax. You can batch fax reports using a fax server. No programming and no integration needed.
From where can we get trial ZetaFax software downloadable in India? Regards
quote:
[8D]
Deepek has u r problem got solved? if yes then how? Regards [:)]
quote:
