Hi, I want to integrate axapta with an application developed in Java. what would be the best way to do it. Regards, Anuj
You can connect to Axapta by Business Logic connector through COM Client. Most of Integration Application (ETL or EAI) use triggers to make intergration. In Axapta you can choose between trigger of DB or Application. Best regards, Khue Trinh
so this one is old but maybe also soe is intrested - use Java Native interface and AX - BC
have an example here :
http://www.flickr.com/photos/jotrox/sets/72157627384220688/
(its connecting Tomcat Servlets with AX Class Functions)
